Comax
#1 Posted : Tuesday, September 28, 2010 5:33:25 AM(UTC)
Comax
I have a Kichen Aide dishwasher that seems to work OK but about 10 min into the washing all the water seems to have drained out and you can hear the pump running dry. At this point I can take a basin of water and fill the cabinet up again, then it works perfect. I should tell you that the unit fills up initially, you can hear the water sloshing for a while, then over the next 10-15 min the pump is running dry. There are no leaks externally. It almost seems like the water is leaking out the drain.
What should I be checking first?
Corey
#2 Posted : Tuesday, September 28, 2010 5:36:53 AM(UTC)
A model number may help others help you.
Also did this unit used to work OK or is this a new install or has the drain plumbing been changed?
Comax
#3 Posted : Tuesday, September 28, 2010 6:22:25 AM(UTC)
Comax
I am in the process of finding my owners manual for the Model number( figured that would be the next question) Should have that shortly.
The unit has been installed and working for over a year now, the drain works perfect. This washer has been working perfectly for at least a year, just about a month ago this problem started.
Corey
#4 Posted : Wednesday, September 29, 2010 4:04:04 AM(UTC)
Comax
#5 Posted : Wednesday, September 29, 2010 7:43:50 AM(UTC)
Comax
I have the model and type for my dishwasher:
Model KUDC03IVBS0 The "I" AND "0" MAY BE 1 AND O hard to tell
Type 577-0
PS
S/N FY1501680
Corey
#6 Posted : Wednesday, September 29, 2010 12:09:27 PM(UTC)
I could not find info on the given model number.
Following tech sheet is for a KUDC03ITBS0
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10130990.pdf
Here is the parts breakdown for that unit
Replacement parts for WHIRLPOOL KUDC03ITBS0 Undercounter Dishwasher | AppliancePartsPros.com
Try running diagnostics to see if that will turn up any clues.
Check that the drain motor is not running all the time.
Comax
#7 Posted : Wednesday, September 29, 2010 1:00:17 PM(UTC)
Comax
Thanks alot!! I'll check over all the valves,switches etc. Pictures are a great help.
Thanks again.
I'll probably be getting back once I have checked everything
Corey
Comax
#8 Posted : Tuesday, January 4, 2011 12:43:22 PM(UTC)
Comax
Finally got to get a good look at my dishwasher and all the inlet valves, motors, etc are functioning properly. I checked to see if the drain motor was running all the time also, it seems to run at the proper time.
The only thing I can't test is the control board. What is the funtion of this board, does it control all the timing and events for the entire dishwasher? If so has anybody heard of these boards working intermitantly or do they just fail all at once and nothing works. Reason I ask is, I tested the dishwasher and it seems to function properly about 1 out of 3 times. I checked all the connectors and they are all tight. Could the control board be failing causing this sporatic operation?
Corey
