lkaymen
#1 Posted : Monday, September 27, 2010 10:06:45 AM(UTC)
lkaymen
whirlpool oven/broiler will not turn on, I can hear the gas solinoid turn on, then off after as second or so, for the oven, have replaced the temp sensor, and controll module, could the problem be in the dsi board? the burners all ignite ok.
Joe / APP Team
#2 Posted : Monday, September 27, 2010 10:39:32 AM(UTC)
Joe / APP Team
Are you sure both the burners in the oven do not work ?
I would have to suspect the DSI module or regulator may be at fault,as well as a loose wire, and would start at the DSI module.
Do you have a meter, to test the resistance and voltage(s) at the DSI or regulator ?
