susanmacrae
#1 Posted : Friday, September 24, 2010 12:49:46 PM(UTC)
susanmacrae
Dishwasher is taking more than 2 hours to run a "normal" cycle....any ideas?
#2 Posted : Sunday, September 26, 2010 11:56:45 AM(UTC)
Replacement parts for WHIRLPOOL KUDI01ILBL3 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208537797.pdf
Often this is a water heating problem.
The unit is waiting for the water to get to the set temperature.
Check that the water filling the unit is at least 120 degrees F.
Unplug the unit and check the heating element for continuity.
Check the hi-limit thermostat, should be 0 ohms.
