alex1421
#1 Posted : Thursday, September 23, 2010 12:26:10 PM(UTC)
alex1421
Hello,
When I turn the left front burner knob to LITE gas comes out but the igniter doesn't spark. This same igniter works fine when I light the left rear burner, so I think that the problem is somewhere in the circuitry. I have located an igniter switch (#716) here: 30" electric ignition replacement parts for General Electric JGBP26GEJ4 Gas range | AppliancePartsPros.com
Is this the part I need to replace or is there more to it?
The model number under the top was partly scrubbed off but the drawings appear to match what I have. There is a circuit diagram on the back dated 1987.
I would be grateful for troubleshooting help.
Regards,
Jim
Joe / APP Team
#2 Posted : Thursday, September 23, 2010 12:37:16 PM(UTC)
Joe / APP Team
Originally Posted by: alex1421 Go to Quoted Post
Hello,
Regards,
Jim
Jim,
It's more likely, that you have a bad spark module,
Part number: AP2023635
But starting at the vlave switch is a good start.
Do you have a multi meter to test the switch circuitry ?
and wiring to eliminate one or the other ?
If not you could order and replace both parts. ??
Part number: AP2024213
Good Luck,
alex1421
#3 Posted : Thursday, September 23, 2010 1:14:31 PM(UTC)
alex1421
OK, I have a multimeter. How best do I gain access to these parts? It looks like I at least have to remove the Control Panel #301. Do I also have to remove the Burner #705 and the Burner box #31?
Jim
Joe / APP Team
#4 Posted : Thursday, September 23, 2010 1:38:23 PM(UTC)
Joe / APP Team
Jim
If you remove the valve knob, and can see the switch on the valve,
You can test the switch, in alot of cases by putting the probes of your meter on the brass rivets holding the switch together and check for a closed circuit when you turn the knob to the lite or on position.
Or you may have to lift the top or remove it and the control panel.
If your switch checks out proper then you will have access to the spark module and wires, it should be located on the left rear side of the burner box base, when you lift/remove the cook top.
alex1421
#5 Posted : Thursday, September 23, 2010 10:34:29 PM(UTC)
alex1421
Thanks Joe. I will have to look at it this weekend.
Jim
Joe / APP Team
#6 Posted : Friday, September 24, 2010 6:09:00 AM(UTC)
Joe / APP Team
Jim
Alex,
Will be looking for your findings, first thing Monday.
Good Luck,
:cool: :cool: :cool:
