NathanWithington
#1 Posted : Tuesday, July 22, 2008 11:25:07 AM(UTC)
NathanWithington
I have a frigidaire upright freezer ( model UF-160T) and I would like to make it into a refrigerator. I have turned the themostat to the lowest (warmest setting) and it still freezes. I have been told to replace the thermostat with a refrigerator thermostat. Will any thermostat work or do I need a certain kind.
Also, there are 2 set screws in the fridgedaire thermostat that say "cut in" and "cut out" with arrrows going in a clockwise direction. Can those set screws be turned to adjust the temperture above 32 degrees?
misterfixall
#2 Posted : Tuesday, July 22, 2008 3:13:44 PM(UTC)
misterfixall
you are wasting your time ,you cannot convert a freezer to a fridge!
abadfish66
#3 Posted : Tuesday, July 22, 2008 3:57:49 PM(UTC)
abadfish66
A domestic freezer compressor will crap out prematurely due to heavy start loads from the high temperature runs and lack of cooling with high compressor temps.
