After a nearby lightening strike, two of the rangetop burners stopped working. You can clearly see on the control panel (AP2995125 made by WHIRLPOOL) that two of the four fuses are blown. However, I can't see how these fuses come out or if they're even meant to be replaceable.
Can anyone tell me if there's a way to replace these fuses, or do I need to replace the entire $250 control panel?
Thanks!
Originally Posted by: SomeOtherGuy  After a nearby lightening strike, two of the rangetop burners stopped working. You can clearly see on the control panel (AP2995125 made by WHIRLPOOL) that two of the four fuses are blown. However, I can't see how these fuses come out or if they're even meant to be replaceable.
Thanks! Did you ever figure this out? I need these fuses as well.
It doesn't appear that the fuses are replaceable.
Bummer! Thanks for your reply. Will look for another used oven!
