Carr Boy
#1 Posted : Thursday, October 11, 2007 4:54:26 PM(UTC)
Carr Boy
The water dispenser on the freezer door of my Kenmore Coldspot Fridge
will sometimes drip after use. This makes for quite a mess if it drips overnight!
Need repair suggestions. Details please. I'm a novice. Thanks
#2 Posted : Friday, October 12, 2007 3:16:16 AM(UTC)
Probably a bad water solenoid in the back of fridg. Also, could be low water pressure to it. When replacing it, check the water pressure by loosing the line to it and verify "decent" pressure. Your solenoid is available by clicking on your model # above.
Carr Boy
#3 Posted : Saturday, October 13, 2007 3:33:17 AM(UTC)
Carr Boy
Could the problem have anything to do with where the water is dispensed? The pressure is good and a glass is filled quickly. I was wondering if an adjustment could be made around the dispensing arm b/f I start replacing parts. Also, I'm unable to find my Model # from the list I have to choose from. If I still need to replace the part, should I use one from another Model?
Thanks.
Admin / APP Team
#4 Posted : Saturday, October 13, 2007 3:33:44 AM(UTC)
Admin / APP Team
Rank: Administration
- Replacement solenoid valve for your Sears model (might look slightly different from the old valve). This is a dual solenoid valve - one solenoid supplies water to the ice maker and another to the water dispenser - this is the solenoid richappy is talking about (only available as a complete valve).
Admin / APP Team
#5 Posted : Saturday, October 13, 2007 3:36:34 AM(UTC)
Admin / APP Team
We don't have your model in our index, but we do carry all parts for it.
- Here is a diagram showing the icemaker, valve and water line
Let me know if you need info on any other part or contact our customer service dept.
Water Dispenser Dripping (Refrigerator & Freezer Repair)
by Loribeth 10/24/2016 8:13:18 AM(UTC)
Kenmore Coldspot Water Dispenser Dripping (Refrigerator & Freezer Repair)
by GlobalGramma 11/4/2011 12:09:28 PM(UTC)
Throught the door water dispenser dripping (Refrigerator & Freezer Repair)
by rgeronimo01 1/12/2011 9:56:54 AM(UTC)
by modernist 3/18/2009 6:21:20 AM(UTC)
