kelbellern
#1 Posted : Wednesday, September 22, 2010 4:27:22 AM(UTC)
kelbellern
The broiler will not light in the oven. The ignitor will light, I even tried to light it with a match. The broiler is not getting gas fed to it it seems. The oven works properly on all settings (i.e. bake, convection bake, roast, convection roast, preheat) but the broiler will not light. Is there something I need to check or replace?
Joe / APP Team
#2 Posted : Wednesday, September 22, 2010 5:17:27 AM(UTC)
Joe / APP Team
You most likely have a weak Broil igniter.
Or at least that's where I would start.
Do you have an ammeter or a multi meter, so you can check it ?
We also need a complete model number(you're missing the last four numbers) to better assist you.
:cool: :cool: :cool:
kelbellern
#3 Posted : Wednesday, September 22, 2010 6:27:11 AM(UTC)
kelbellern
I will have my husband check the ignitor, the model is 79078869803. Kenmore gas range/oven.
Joe / APP Team
#4 Posted : Wednesday, September 22, 2010 7:37:52 AM(UTC)
Joe / APP Team
OK,
Sounds good to me.
If he has an ammeter when the igniter is on and glowing he should read a minimum of 3.2 amps or 3.2 volts AC at the broil burner terminals on the oven dual burner valve.
Here's the part number for the broil igniter, if you need it.
Part number: AP3963540
Good Luck,
Oven and Broiler will not light (Oven Repair (including Ranges and Cooktops))
by TAUSTIN13 9/1/2013 3:32:05 PM(UTC)
Maytag oven and broiler will not light (Oven Repair (including Ranges and Cooktops))
by pddudak 2/17/2012 6:13:49 AM(UTC)
Oven & broiler will not light (Oven Repair (including Ranges and Cooktops))
by C Dale 7/13/2011 4:55:34 PM(UTC)
Oven & Broiler will not light (Oven Repair (including Ranges and Cooktops))
by ThomasN 6/10/2010 8:08:28 AM(UTC)
by mmason3122 1/6/2009 6:30:32 AM(UTC)
