mmason3122
#1 Posted : Tuesday, January 6, 2009 6:30:32 AM(UTC)
mmason3122
Hi
My oven is a Amana args7650ww
s/n 0008131794
manufacture # p1130765nww
The broiler does not start. What can I do to fix it.
#2 Posted : Tuesday, January 6, 2009 8:19:04 PM(UTC)
Does the igniter glow?
If it does but the gas does not flow then the igniter is bad and has to be replaced.
If it does not then you have to disconnect the igniter wires and check for 120VAC to the igniter while the control calls for Broil.
If there is 120VAC then the igniter has to be replaced.
If there is no proper voltage then the control board has to be replaced.
- The part number for the Broil igniter is AP2934763. You have to use the bracket from the old igniter.
- The part number for the control board is AP4041311
mmason3122
#3 Posted : Wednesday, January 7, 2009 6:04:07 AM(UTC)
mmason3122
Thanks for the help.
How do check for the power?
Do I need to remove the back panel from the stove?
Matt
#4 Posted : Wednesday, January 7, 2009 12:06:50 PM(UTC)
Matt,
You have to have a simple multimeter.
You have to pull the igniter out as far as the wires will let you. There should be a wire nuts for each wire. Disconnect these wire nuts and measure the voltage between the two wires coming to the igniter while the control calls for Broil.
If you can pull the range out of the wall and remove the rear panel, then you can access the igniter wires easier way.
spystyle
#5 Posted : Tuesday, November 23, 2010 7:53:39 AM(UTC)
spystyle
Good luck :)
Oven and Broiler will not light (Oven Repair (including Ranges and Cooktops))
by TAUSTIN13 9/1/2013 3:32:05 PM(UTC)
Maytag oven and broiler will not light (Oven Repair (including Ranges and Cooktops))
by pddudak 2/17/2012 6:13:49 AM(UTC)
Oven & broiler will not light (Oven Repair (including Ranges and Cooktops))
by C Dale 7/13/2011 4:55:34 PM(UTC)
by kelbellern 9/22/2010 4:27:22 AM(UTC)
Oven & Broiler will not light (Oven Repair (including Ranges and Cooktops))
by ThomasN 6/10/2010 8:08:28 AM(UTC)
