2 Pages12>
PaulsStuck
#1 Posted : 15 years ago
PaulsStuck
The tray to my icemaker has been periodically sheading its lining into my ice for some time now. So when it stopped making ice (and built up frozen water in it), I replaced the entire 8-part assembly with a replacement from appliancepartspros.com.
After installing it, I have received about 4 batchs (8-pieces each) of ice over the past week - some ice but that's it! It has water in the tray, but the ice does not come out.
What do I look at next to solve this issue?!
#2 Posted : 15 years ago
What is the exact temperature in the freezer?
It suppose to be 0°F ± 5°F.
If the temperature is fine and the part you replaced in the ice maker is the ice mold, very likely you did not attach the thermostat properly or overlooked some more wrong parts. The ice maker repair is not that simple and the rate of success on such repairs is relatively low. I'm personally do not do it. New ice maker is more expensive but on the other side it is much more reliable to replace the whole ice maker.
- The ice maker Part number: AP3182733
PaulsStuck
#3 Posted : 15 years ago
PaulsStuck
Thank you for your fast reply!
I did replace the entire ice maker for $120 - I thought that the motor went bad and I had to replace the tray anyway - from what you say, I did the right thing.
I just went upstairs and there were 8 cubes in the bin - it seems like if I mess with the bin, the door and the on/off switch, I get a few cubes out, but hardly any.
I was thinking that perhaps I hadn't hooked the laser connection back right - I had to replace the flipper when I accidently broke it taking the icemaker out. I have not tried to reconnect it yet b/c somtimes ice DOES come out....
PaulsStuck
#4 Posted : 15 years ago
PaulsStuck
Freezer is set to 0 deg F.
#5 Posted : 15 years ago
The temperature you set and the real temperature can be different. If you want to make sure there is the correct temperature, you have to measure it. The most accurate thermometer is a mercury.
PaulsStuck
#6 Posted : 15 years ago
PaulsStuck
When freezer set at 0F, flat thermometer (not mercury but I will get one) said -8F and the freezer seems colder than normal. I increased the set temp so that thermometer reads -2F in case it was too cold and frezzing up mechanics of icemaker, but still no ice.
I checked that I put the wire back into the laser assembly when I changing out the flipper (remember I broke accidently when taking out icemaker to replace) and it seems to be fine. Is there a way to check the laser?
PaulsStuck
#7 Posted : 15 years ago
PaulsStuck
I just used my camcorder, which has a "Nightshot" mode that detects IR, and manually pushed the flipper and the freezer door switches in and did not see any laser from either side. The camcorder works b/c I could see the laser from my remote.
Is there another way to test the laser - perhaps w/a multimeter? where/how would I test? If this is not working I would think that the freezer thinks that the ice is full and would explain why not working, or at least workign intermittently, right?
PaulsStuck
#8 Posted : 15 years ago
PaulsStuck
Freezer temps back to 0F and the icemaker is making ice - at least for the past 24 hours it has been.
Hopefully this is fixed - did the freezer freeze up the icemaker? Is that what you think might have happened?
#9 Posted : 15 years ago
...did the freezer freeze up the icemaker? Is that what you think might have happened?...
I do not think so. More likely there is a bad connection somewhere.
PaulsStuck
#10 Posted : 15 years ago
PaulsStuck
You are like me: the bearer of "bad-tidings". Actually once you said that I think that you are right -I recall 1 or 2 times where the the ice quantity in the bucket dropped - as if the maker stopped working.
Where might you think that the problem is? Or is there a way to tell based on the the description I have given? Does the laser run all the time when the door is closed or periodically? Does it fire on a timer or in coordination with ice production?
2 Pages12>
