wilson973
#1 Posted : Monday, September 20, 2010 5:54:54 AM(UTC)
wilson973
About every 5 days I have to take my back panel off my freezer side and use a hair dryer to melt the ice off the coils. Is there a defrost timer on this model Maytag LSD2615HEW? I have search and cant tell. When I take the panel off the fan is working until I unplug it. Any kind of help would greatly be appreciated.
Joe / APP Team
#2 Posted : Monday, September 20, 2010 8:19:43 AM(UTC)
Joe / APP Team
Wilson,
No you do not have a defrost timer, in this unit.
You have an Adaptive Defrost Control assembly(board).
Part number: AP4010220
It is lacated inside the control assembly on the side wall of the fresh food compartment,
Have you checked your defrost thermostat and heater , yet ?
Good Luck,
:cool: :cool: :cool:
wilson973
#3 Posted : Monday, September 20, 2010 8:25:37 AM(UTC)
wilson973
No I havent checked either yet. Not to sure on how to check sensor. I can do a resistance check on the element.
Joe / APP Team
#4 Posted : Monday, September 20, 2010 10:02:13 AM(UTC)
Joe / APP Team
Wilson,
You check the heater and the thermostat, the same way.
The heater should have a closed circuit or approximately 20 ohms resistance(depending on what resistance scale you use.
The thermostat should be an open circuit(no resistance) at room temperature and a closed circuit below 35 degrees.
If both components check properly, you will need an ADC board.
Were it me, I would replace the inoperative part and the ADC board, but that's just me.
Good Luck,
