dsell
#1 Posted : Monday, September 17, 2007 1:09:05 PM(UTC)
dsell
Our washer stalled after it filled with water -- I could go back and start the wash cycle over and it did agitate. I drained it by hand by lowering the hose into a bucket on the floor (not plugged) -- checked the lid switch, and the screw holders have crumbled -- so I will replace this. But -- I after switching it on by hand -- the water would not drain. Is there anything else I can check before ordering a new pump. -- thanks
#2 Posted : Monday, September 17, 2007 4:04:24 PM(UTC)
Take the hoses off the pump and check for a clog.
dsell
#3 Posted : Monday, September 17, 2007 7:33:45 PM(UTC)
dsell
Hoses are clear. Pump is clear. I can turn the workings of the pump with some effort -- is it supposed to spin freely?
#4 Posted : Tuesday, September 18, 2007 12:28:51 AM(UTC)
Does the motor run in drain mode?? Does it agitate in drain mode?
dsell
#5 Posted : Tuesday, September 18, 2007 6:49:58 AM(UTC)
dsell
Before I disassembled it: if I put the dial in drain mode -- no sounds -- no agitation -- nothing. After I hand drained the basket-- it would spin in spin mode (although clunky). Is there an additional way that I need to test this?
