afrofistpick
#1 Posted : Monday, July 21, 2008 11:12:02 AM(UTC)
afrofistpick
While washing a load of towels, my washer stoped working. I think it finished it's cycle, but it will not start again. It's a front load wahser. When I try to run a cycle, I hear the door lock, but all I her is a humming sound with no movement or water filling. I tried reseting the breaker and leaving the washer sit for over an hour before trying again; no luck. Is there anything else I can check or do? Is this somehthing I can fix myself? :confused:
afrofistpick
#2 Posted : Monday, July 28, 2008 2:35:28 AM(UTC)
afrofistpick
It turns out that something got stuck in the motor, which stopped the motor from turning. To fix it, it was just a matter of opening the botttom of the washer, unhooking the hose that is connected to the motor and checking and removing the items. If you have a wetvac it will be helpful to clean up the water.
washer fills with water, but wont aggitate. it hums for about 5 seconds & shuts off (Washer Repair)
by liquidarrows 7/27/2011 1:33:18 PM(UTC)
Kenmore(1998) Series 80 will not start, it hums (Washer Repair)
by deacontry 8/20/2009 1:33:10 PM(UTC)
