RHCHomeowner
#1 Posted : Sunday, July 20, 2008 5:45:47 PM(UTC)
RHCHomeowner
The rental condo has a AMANA refrigerator and the evaporator coils are frozen solid.
So, that means that the defrost heating isn't working.
How to fix that?:confused:
Thank you!
#2 Posted : Monday, July 21, 2008 3:04:31 PM(UTC)
In order to provide most accurate advise we need the complete model number of the fridge.
okbobcats
#3 Posted : Tuesday, July 22, 2008 3:37:36 AM(UTC)
okbobcats
ohm out your bi-metal and heater in freezer section. if they check good you have a bad defrost timer.
calcio
#4 Posted : Thursday, July 31, 2008 2:48:48 PM(UTC)
calcio
What should the readings be for these two parts?
I checked the heater element and got about 29 (on a cheap multimeter set to the K(ohm) setting)
As for the bi-metal thermostat, I got a resistance of about 230. (although there is an orange wire going thrrough a hole to the back of the refrigerator. I think that simply ends at a tester connection, but maybe it goes to something else)
Thanks,
Calcio
(Amana side by side refrigerator - Model # SXD26VW)
okbobcats
#5 Posted : Friday, August 1, 2008 3:02:07 AM(UTC)
okbobcats
Those reading sound pretty good. looks like you need a defrost timer
