I have a Whirlpool gas dryer and it will not heat up. we can see that the drum is getting hot but something will no allow the gas to blow out so that the flames will light. we are not sure whether to buy the kit containing two coils or the harns wire. AP3130553 LGR7646AWO AP3094251
Replace the coils Part # AP3094251 this will fix your problems
Originally Posted by: isewforu I have a Whirlpool gas dryer and it will not heat up. we can see that the drum is getting hot but something will no allow the gas to blow out so that the flames will light. we are not sure whether to buy the kit containing two coils or the harns wire. AP3130553 LGR7646AWO AP3094251 replace the coils they cause really strange failures and are the common cause of most...
