usbradleys
#1 Posted : Thursday, September 16, 2010 10:42:55 AM(UTC)
usbradleys
I own a Duet and the moisture sensor is not working correctly. The error code reads 02. Can somebody please tell me what parts that I need to order to fix my problem?
Run Down!
The loads dry but not fully.
The vent is free and clear.
The exterior exhaust is opening correctly.
I ran the diagnosis and was supposed to get a reading of 03 but received an 02.
Thank you in advance for any help that you can give.
Joe / APP Team
#2 Posted : Thursday, September 16, 2010 12:49:46 PM(UTC)
Joe / APP Team
Run Down!
US,
I am not aware of a 02 or 03 as an error code on this unit, or as a test mode display.
Here is the Technical Data Sheet for your unit (GGW9200LL1)
http://www.servicematters.com/d...0Sheet%20-%208541834.pdf
Please re run the tests using this information
And contact us if you need more assistance.
Thanks,
