Indiana73
#1 Posted : Thursday, July 17, 2008 4:15:11 PM(UTC)
Indiana73
Ice maker is not making ice. Water valve has continuity and has water going to it. Water line entering freezer is not froze or clogged. Did not test water pressure - don't know how. And freezer temp between 14 and 17 degrees (F). Will installing a replacement ice maker get me ice or are there other possible problems that will keep the replacement unit from working?
#2 Posted : Thursday, July 17, 2008 6:36:37 PM(UTC)
The first thing which needs your attention if the temperature in the freezer is too high. Normal freezer temperature should be between 0°F to 5°F. Such high temperature is not safe for the food and can affect the ice maker performance. Try to set it lower.
Here are the break down diagrams for the Frigidaire refrigerator Model FRT21NNGD1
Indiana73
#3 Posted : Friday, July 18, 2008 11:24:00 AM(UTC)
Indiana73
Gene, with both freezer and fridge set at coldest settings freezer only get down to 14 degrees. What need to be done to get freezer colder? Is this why I'm not getting ice?
#4 Posted : Friday, July 18, 2008 12:34:06 PM(UTC)
Is the rear panel in the freezer covered with frost?
If it's not then remove this rear panel and check how the evaporator coils (#17 on the break down diagram) covered with frost.
Post the results.
Indiana73
#5 Posted : Friday, July 18, 2008 5:39:02 PM(UTC)
Indiana73
Gene, the rear panel has some frost, slight to moderate, on the lower portion.
#6 Posted : Friday, July 18, 2008 7:26:25 PM(UTC)
Remove the panel and check frost on the coils. Post your findings.
Indiana73
#7 Posted : Saturday, July 19, 2008 7:10:44 AM(UTC)
Indiana73
Yes there is frost on the coils.
Should I defrost the entire fridge?
Kevin
