bedeker5
#1 Posted : Monday, September 13, 2010 1:08:29 PM(UTC)
bedeker5
Estate washer will not spin/agitate on any cycle. It will fill with water, and drains fine on the spin cycle, but will not spin at all. The motor hums as if it is trying to work. Belt looks fine. Drum will spin by hand.
sidfink43
#2 Posted : Tuesday, September 14, 2010 5:31:58 PM(UTC)
sidfink43
I cannot get you model number to come up, but if this is a Whirlpool made direct drive washer it does not have a belt, so I do not know what you are looking at.
Your symptoms indicate a broken motor coupling, an easy and inexpensive repair. Check out this video.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
bedeker5
#3 Posted : Wednesday, September 15, 2010 9:26:16 AM(UTC)
bedeker5
Sorry, the model number should be TAWS750PQ0.
Local repair shop wanted us to try to replace the agitator dogs first, but if that doesn't work, we'll try the motor coupling. Thanks!
#4 Posted : Wednesday, September 15, 2010 1:43:35 PM(UTC)
As sidfink43 said, your washer is direct drive and it does not have any belts. The problem you described has nothing to do with the agitator dogs. Most likely the problem is a bad motor coupling. Remove the washer cabinet in inspect the motor coupling.
- The motor coupling Part number: AP3963893
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL TAWS750PQ0 Automatic Washer | AppliancePartsPros.com
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 97 time(s).
How to replace the motor drive coupling.doc (25kb) downloaded 87 time(s).
Estate Washer Will Not Spin (Washer Repair)
by Shadowjedi 1/3/2012 9:47:56 AM(UTC)
Estate washer will not spin after it drains (Washer Repair)
by twisted2b 8/24/2009 8:03:16 PM(UTC)
Estate washer will not spin (Dishwasher Repair)
by rooster9 7/22/2009 5:02:59 PM(UTC)
