2 Pages12>
jf1942
#1 Posted : Wednesday, March 12, 2008 8:14:52 PM(UTC)
jf1942
I know the part I need and would like help in removing door to replace broken latch. Part #WB10X10021 .
#2 Posted : Thursday, March 13, 2008 4:33:05 PM(UTC)
I do not think you have to remove the whole door for this job.
Remove the choke cover first and you should get access to the door latch. The video clip from one of previous posts can help you.
- The APP part number for the door latch is AP2020315
Here are the break down diagrams for the GE microwave Model SCA2000BWW03
VLNPRVHPR
#3 Posted : Tuesday, July 15, 2008 8:16:54 AM(UTC)
VLNPRVHPR
Hi JF1942 & Gene. I have similar problem. Will a broken Part Number AP2020315 keep the microwave from heating? The microwave was working fine a few minutes before the latch broke. My Model Number is GE, SCA1000HWW02 from Year 2005. The microwave acts exactly the way it used to except since breaking the latch, it just won't heat anything up. Thanks.
#4 Posted : Tuesday, July 15, 2008 1:50:39 PM(UTC)
Originally Posted by: VLNPRVHPR Go to Quoted Post
...Will a broken Part Number AP2020315 keep the microwave from heating?...
Yes, definitely it will. Replacing this door latch & spring assembly should solve the problem.
VLNPRVHPR
#5 Posted : Tuesday, July 15, 2008 1:54:30 PM(UTC)
VLNPRVHPR
Would I have to do anything or fix anything on the Microwave itself? Like the area where the latch actually locks into? I have already ordered the part and should get it by Friday at the latest. I will update the results and hopefully everything will work and heat the contents. Thanks.
#6 Posted : Wednesday, July 16, 2008 1:39:03 PM(UTC)
Lets do one thing at a time. Replace the door latch and post the result.
VLNPRVHPR
#7 Posted : Thursday, July 17, 2008 10:29:10 AM(UTC)
VLNPRVHPR
I changed the latch last night and well, everything is back to normal. Thanks for all of your help.
#8 Posted : Thursday, July 17, 2008 11:21:51 AM(UTC)
I'm glad you were able to fix it.
petieriley
#9 Posted : Friday, March 12, 2010 3:30:42 PM(UTC)
petieriley
I have the same problem but do not know how to get the old broken latch out? There is a spring thats hard to get at?
Originally Posted by: kcoen Go to Quoted Post
I have a GE over counter microwave oven. The day after listing my house for sale, I got my bracelet caught on the bottom plastic door latch and broke if off. If I order that part, can it be replaced by the comsumer? And how easy is it to do?
petieriley
#10 Posted : Friday, March 12, 2010 3:32:56 PM(UTC)
petieriley
Can you help me? I have a GE Spacemaker over with a broken latch. I got the panel off to access the latch but there is a spring thats hard to get at that hold the latch. Not sure how to get that out?
2 Pages12>
