JodyG
#1 Posted : Wednesday, July 16, 2008 3:01:47 PM(UTC)
JodyG
While working, the oven began to make a poof sound. It became more frequent. Then the oven wouldn't heat. I removed the floor and discovered the oven was lighting, going off, relighting...over and over. Do I need a new igniter, gas valve or both?
#2 Posted : Wednesday, July 16, 2008 8:28:00 PM(UTC)
Hi Jody,
If the igniter stays "on" while the flame goes "on" & "off" then the igniter is bad.
If the igniter goes 'on' & 'off' then the control board is bad.
- The part number for the igniter is AP205873
The control board is no longer available.
