karlie52
#1 Posted : Saturday, September 11, 2010 9:00:02 AM(UTC)
karlie52
I have a maytag refrig. The freezer inside door keeps frosting up an I have ice on the top of freezer. The seals are good an no one left the door open. It seems to be worse in warm weather. If someone has any suggestions it would be appreciated! This has a adaptive defrost heater. Does any know how to turn the defrost heater on? Thanks!
#2 Posted : Sunday, September 12, 2010 2:18:25 AM(UTC)
There is no easy way to force defrost on this. Take the freezer temperature and post.
I would use a hair dryer to defrost the ice and look for a partially blocked vent or a blocked air return vent behind the crisper drawers.
#3 Posted : Sunday, September 12, 2010 3:57:59 AM(UTC)
Defrost should not effect frost/ice on the door.
I would recheck the door seal, it should compress slightly when closed.
Refrigerator Repair Guide: How to Check the Door Seals - ACME HOW TO.com
Check the door closure on the bottom hinge see Section 5 in the parts.
karlie52
#4 Posted : Sunday, September 12, 2010 4:51:25 PM(UTC)
karlie52
I checked the door gasket it seems o.k.. This refrig. has ice &water through the door. I'm wondering maybe the ice chute door is sticking open! I've had 2 times in the last 6 yrs. where the inside door has frosted up top to bottom. Thanks for your help!
