My freezer suddenly stopped freezing. Do I need freon or is it time to buy a new refrigerator??? Help!!!
Is the freezer and condenser fan running?
yes, and it sounds like normal except the ice maker stopped making ice.
Pull the back panel of the refrigerator and check the compressor, if cold, remove the cover of the motherboard and remove the motherboard, but keep the connectors in place, just tilt it up. Check the solder connections by the big power relay. If bad, just clean it up and re-solder. If ok, replace the motherboard AP4436216
