I have a Whirlpool microwave, Model #MH7130XEB-1. The microwave is completely dead, no display, lights, etc. Can't hit any buttons, anything. Completely dead.
Looking for a repair manual to try to troubleshoot. Is this a common problem? Any idea of the cause?:confused:
take the front off. there is a fuse behing the control panel. replace it and all will be good.
Please be sure to unplug the microwave unit before messing with any of the innards or changing the fuse. There are capacitors inside that may hold a 4000 volt charge for a long time.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My microwave has an āEā on the tome display. Now everything is dead. Any suggestions?
