thomasc
#1 Posted : Friday, September 10, 2010 12:27:26 PM(UTC)
thomasc
How do I remove the spray arm? Do I have to go in from under the dishwasher or can I remove it from inside? Also, what tools will I need to remove it?
Thanks,
Tom
#2 Posted : Friday, September 10, 2010 2:28:38 PM(UTC)
Tom,
What is wrong with the dishwasher?
Why do you need to remove the spray arm?
Here are the breakdown diagrams and Replacement parts for General Electric GSD4100J00BB Dishwasher | AppliancePartsPros.com
thomasc
#3 Posted : Sunday, September 12, 2010 8:29:32 AM(UTC)
thomasc
Tom,
The plastic cylinder that pops up from inside the sprayarm during washing cycle is broken. How do I get the sprayarm off, and what tools will I need?
Thanks,
Tom
#4 Posted : Sunday, September 12, 2010 2:22:20 PM(UTC)
Tom,
This spray arm is threaded into a part under the tub/liner of the dishwasher. A rubber coupler on top of the motor and pump assembly is what this spray arm assembly screws/threads into. To remove this spray arm, simply push a flat screwdriver through the hole in the bottom of the spray arm and twist it off.
- The spray arm assembly Part number: AP2039841
GE Nautilus Dishwasher (Dishwasher Repair)
by Curt Brennan 7/30/2015 10:38:58 AM(UTC)
GE nautilus dishwasher (Dishwasher Repair)
by golfingman 4/18/2014 3:37:08 PM(UTC)
GE nautilus dishwasher doesn't push water to top arm and won't drain (Dishwasher Repair)
by ole joe 7/19/2011 5:50:24 PM(UTC)
GE Nautilus Dishwasher making noise (Dishwasher Repair)
by Krowell 12/10/2010 6:27:22 AM(UTC)
by Jess9375 11/30/2010 3:32:34 PM(UTC)
GE Nautilus Dishwasher Won't Drain (Dishwasher Repair)
by gunnermel 10/14/2009 3:58:56 PM(UTC)
GE Nautilus dishwasher drains continuously (Dishwasher Repair)
by slk 9/18/2009 1:52:40 PM(UTC)
GE Nautilus Dishwasher: Trouble starting (Dishwasher Repair)
by jmrec100 5/25/2009 10:19:14 AM(UTC)
GE Nautilus Dishwasher Not Draining (Dishwasher Repair)
by c3uo 3/10/2009 4:24:15 PM(UTC)
