How do I remove the spray arm? Do I have to go in from under the dishwasher or can I remove it from inside? Also, what tools will I need to remove it?
Thanks, Tom
Originally Posted by: Gene  The plastic cylinder that pops up from inside the sprayarm during washing cycle is broken. How do I get the sprayarm off, and what tools will I need? Thanks, Tom
Tom, This spray arm is threaded into a part under the tub/liner of the dishwasher. A rubber coupler on top of the motor and pump assembly is what this spray arm assembly screws/threads into. To remove this spray arm, simply push a flat screwdriver through the hole in the bottom of the spray arm and twist it off. - The spray arm assembly Part number: AP2039841
