tony51
#1 Posted : Tuesday, July 15, 2008 8:34:19 PM(UTC)
tony51
Lights work,both fans running.Refridgerator not cold.
#2 Posted : Wednesday, July 16, 2008 1:56:34 AM(UTC)
Check the compressor, if running, measure the freezer temperature and post.
tony51
#3 Posted : Wednesday, July 16, 2008 7:48:44 AM(UTC)
tony51
When I plug it in temp was 80,I could hear the fans start.After a few minutes the compressor kicked on,let it run a while temp 78.I pulled the cover in back of frezer and the line was frosted up coil barely cool.
#4 Posted : Wednesday, July 16, 2008 1:03:26 PM(UTC)
You have refrigeration problems for a pro to fix.
tony51
#5 Posted : Wednesday, July 16, 2008 2:07:27 PM(UTC)
tony51
Does that mean a freon leak?
#6 Posted : Thursday, July 17, 2008 2:03:33 AM(UTC)
Without measuring the gage pressure of the compressor ports, it could be a bad compressor, or a refrigerant leak.
