dude67
#1 Posted : Monday, July 14, 2008 9:05:10 PM(UTC)
dude67
My oven sometimes works good and sometimes not so good. The bottom element works great for a while and then when you are baking something you find that it is not cooked because the bottom element has quit working. Any help will be appreciated. Thanks
#2 Posted : Tuesday, July 15, 2008 4:41:11 PM(UTC)
Is the oven gas or electric?
If it's gas then most likely the problem is a bad igniter.
The model number you posted does not come up and I'm not able to provide more accurate advise.
dude67
#3 Posted : Wednesday, July 16, 2008 2:22:00 PM(UTC)
dude67
Hi Gene,
Regarding the Bottom element working intermittently. It is an electric Kenmore Range
Model # C880 639839G5
Serial# IML1885098
Type 30p
#4 Posted : Wednesday, July 16, 2008 2:26:08 PM(UTC)
The model number you posted does not come up. This is probably not American model and, unfortunately I'm not able to find any information on-line.
Guest (5)
