no lights on panel. water in tub. seems like there is no power to it. I replaced panel a few months ago (Thanks Gene!). Cirvuit breaker in house is ok.
Thanks,
Pete
THIS FORUM IS DEAD!!!!!!! |
The board did not come with anything else but the entire control board and wires. The info attached does not tell me about a fuse/circuit breaker same for parts.
Originally Posted by: pdel11  The board did not come with anything else but the entire control board and wires. The info attached does not tell me about a fuse/circuit breaker same for parts. Now I see it, sorry. Will order fuse. thanks
