bjmura3
#1 Posted : Friday, September 10, 2010 8:43:25 AM(UTC)
bjmura3
My dryer will heat the clothes and spin however the air does not flow so all I have is very wet hot clothes
Brian Scott
#2 Posted : Saturday, September 11, 2010 9:43:29 AM(UTC)
Brian Scott
Check to make sure your vent pipe is not clogged. THat is a common problem. Make sure it is clean and clear all the way to the outside. Also make sure it isn't pinched or kinked in any way. :eek:
#3 Posted : Saturday, September 11, 2010 12:42:34 PM(UTC)
Could be the blower wheel has stipped out internally and is no lo loneer turning when the motor turns.
Could be something has fallen into the blower assembly.
Strange that it did not blow the thermal fuse.
GE no air flow (Refrigerator & Freezer Repair)
by 8Toni8 9/15/2015 8:15:56 AM(UTC)
No Air Flowing On Top (Refrigerator & Freezer Repair)
Belarus PYTHON844 12/14/2014 8:19:42 PM(UTC)
No air flow to top of refrigerator and freezer (Refrigerator & Freezer Repair)
by auxion1 5/26/2013 4:42:50 AM(UTC)
dry help no heat no air flow after noise (Dryer Repair)
by ronlisatayty 3/28/2010 11:01:09 AM(UTC)
Fridge side is warm,no air flow from freezer (Refrigerator & Freezer Repair)
by scottbittner 7/9/2009 6:29:03 AM(UTC)
No Air Flow (Oven Repair (including Ranges and Cooktops))
by paulmaudlin 7/3/2009 5:34:47 AM(UTC)
