auxion1
#1 Posted : Sunday, May 26, 2013 4:42:50 AM(UTC)
auxion1
Views messages in topic : 1
I have an Amana side by side more than 10 years old Model SXD22Q2W. The bottom part of the refrigerator and freezer get cold, but the top stays warm. There is no circulation of the cold air. Is there a fan relay that I need or is it something major? Thanks...Molly
#2 Posted : Monday, May 27, 2013 2:07:56 AM(UTC)
SXD22Q2W
Note: I could not find a tech sheet for your exact model number. The attached is for a SXD22S2. Hopefully it is a close match to your unit.
Check across the evaporator/freezer fan with a meter.
If it has 120 volts and is not running, replace the fan.
File Attachment(s):
SXD22S2.pdf (181kb) downloaded 2 time(s).
