2 Pages<12
BJF
#11 Posted : Friday, September 10, 2010 3:22:28 AM(UTC)
BJF
Using the Fluke 114,and disconnecting wires going to the thermal fuse, I touch the posts on both sides and reading is OL. I think this means zero Ohms- does this sound right?
#12 Posted : Friday, September 10, 2010 3:56:36 AM(UTC)
No, I think 0L on most meters is an open not a short.
Just short your meter leads together, this will show you what 0 ohms should look like.
wgcoop629
#13 Posted : Sunday, September 12, 2010 11:10:00 AM(UTC)
wgcoop629
Originally Posted by: BJF Go to Quoted Post
I purchased the microcomputer and received the control board along with a suppressor board. My oven did not have a suppressor board, but I installed it according to the instructions that came with the part.
Installed the control board and tested a bake......STILL no heat. AAAUUUGGHH. Anybody have an idea what else could be happening?
Also tried a Broil- no heat. What else can I try? (I did reconnect the thermal fuse prior to finishing installation....
Did you get your oven to work. I'm having the same problem with a frigidaire oven after the bake element burned out. I hate to buy a new control board if that's not the problem.
BJF
#14 Posted : Sunday, September 12, 2010 12:29:11 PM(UTC)
BJF
Got a replacement thermostat fuse and it worked. Took out the microcomputer and replaced with old one and its still works, so this was due to the thermal fuse. Mine was due to the thermal fuse, so maybe your is as well?
I must have been reading the meter wrong when testing that part earlier.
denman- you were right, the fuse was broken so it was wide open. Thanks!!!
wgcoop629
#15 Posted : Sunday, September 12, 2010 1:01:29 PM(UTC)
wgcoop629
Thanks. I check the thermostat and it was 0 ohms
2 Pages<12
