Have seen this problem posted several times, but ...
The upper oven stopped working. Everything works perfect except no heat from top or bottom element. Control panel works perfect, clock is fine, preheat displays, time bake, everything!
I replaced the back thermostat # 4451442 with part # 37 from this site (it is called thrmst-fix, part looks a lot different from original, but I trusted it) ... no difference.
Now what? I really dont want to get Whirlpool out here - I am 45 minutes to closest repairman. It is my understanding if the control panel thermal fuse blew, then the control panel would not be working, correct?
It seems odd that both elements would have went bad at same time, but keep in mind that I know nothing about this stuff. I just have a repair manual and follow directions well!
Thanks in advance for any help you can give.
Hi TOMF,
You have to have a simple multimeter and to proceed with troubleshooting. If you are - let us know and we'll guide you through.
Gene. OK Gene, that puts me a little out of my comfort zone, but willing to try! Can I pick one up at a WalMart store that I will be close to today? Thanks.
You can do it at any store. It should have ability to measure voltage as well as resistance.
Gene,
How do I remove the trim pieces on the double oven to remove the unit from the wall, it as a Whirlpool unit GBD307PDS7.
I too have a unit not working after activating the self cleaning function.
I bought the thermo fuse and need to replace it.
Thanks.
steffco1,
Open the lower oven door and remove the screw on each side trim. Pull the trim from the bottom and slide it down .
Gene,
I have the multimeter ... ready for orders!
Please be detailed as this is first time using this device. Thanks.
Tom
ok, read it ... what do we want to test first?
Hi Tom,
Turn off the oven circuit breaker.
Open the lower oven door, remove the screw on each side trim, pull the bottom of the trim toward yourself and slide it down to release it from the control panel tab.
Remove the screw on the bottom of each side of the control panel. Pull the bottom of the control panel toward yourself and up to release it from the tabs.
Locate two identical relays on the control board with two wires plugged into each of the relays - 2 red wires into one relay (we will cal it relay#1) and one red and one red with white strip into another (relay#2).
Remove the red wire from the relay#2 and both red wires from the relay#1. Check for continuity between the first red wire (relay#2) and each of the red wires from the relay#1. Mark the red wire (relay#1) which has the closed circuit with the red wire (relay#2).
Plug this wire and the red wire from the relay#2 back in place, living the second red wire from the relay#1 out (insulate it).
Turn the oven circuit breaker on. Turn the Bake on the upper oven on and check for 120VAC between the terminal on the relay#1 where the red wire was connected and ground.
Post the results.
