2 Pages<12
#11 Posted : Monday, July 14, 2008 4:19:52 PM(UTC)
oven,
What is the complete model number and make of the unit?
numbers
#12 Posted : Monday, July 14, 2008 7:28:12 PM(UTC)
numbers
Vgrc4856qd58
#13 Posted : Monday, July 14, 2008 8:33:38 PM(UTC)
numbers,
Viking does not provide any information on-line but if you can be more specific on the problem and description of the unit we might be able to help you.
numbers
#14 Posted : Tuesday, July 15, 2008 7:21:29 AM(UTC)
numbers
I am working on a viking stove model # VGRC4856QDS8. The spark modules would continue to spark even after the the flame was lit. If you turned on either the 3 burners on the right side, or the 4 burners on the left side, the spark would stop and the stove would work properly. I replaced both spark modules with a 4 point re-igniter from tytronics. I also replaced all 7 spark ignitors and I still have the same problem.
#15 Posted : Tuesday, July 15, 2008 1:45:14 PM(UTC)
Most likely the cause of the problem is one or more igniters. Bad ground, excessive grease or cracked ceramic insulation - that's what you have to look for.
numbers
#16 Posted : Tuesday, July 15, 2008 2:48:45 PM(UTC)
numbers
Quick Reply.
numbers
#17 Posted : Tuesday, July 15, 2008 2:51:48 PM(UTC)
numbers
Thank you. I'll check for bad grounds. The ignitors are new and there is no grease.
Chikunlai1
#18 Posted : Tuesday, November 4, 2008 7:15:25 PM(UTC)
Chikunlai1
I have the same problem with all (4) of the stove's ignitors spark continuously even when none of the burner switch is turned on. I replaced the ignitor module but the problem has remained. The ignitors spark continuously even when the wire to all four burner switches were disconnected. I had to unplug the range and have been using a match for several years. I am hesitant to buy a second new module since the first one costed $150 and it didn't solved the problem.
My range is a Kenmore moel 911 7360190. The original module is Harper-Wyman 6526. The replacement module is Harper- Wyman 6540.
I appreciate any help.
#19 Posted : Wednesday, November 5, 2008 4:26:31 PM(UTC)
Originally Posted by: Chikunlai1 Go to Quoted Post
...(4) of the stove's ignitors spark continuously even when none of the burner switch is turned on. I replaced the ignitor module but the problem has remained. The ignitors spark continuously even when the wire to all four burner switches were disconnected...
It could be defective new part, reversed polarity on the electrical connection for the spark module or missing ground.
christycal
#20 Posted : Monday, November 24, 2008 10:57:21 AM(UTC)
christycal
I had the same problem. None of my igniters worked so I replace the ignition module. All of the igniters sparked when any burner was lit. I used the same ground screw location as the original module when I installed the new module. Just for grins I tried screwing the ground wire into a different location. Voila - problem solved!
2 Pages<12
