Paul Radovsky
#1 Posted : Monday, July 14, 2008 10:34:28 AM(UTC)
Paul Radovsky
I have a GE dishwasher GSD4310Y73AA which no longer drains enough water out. I assume the pump went bad. Is WD19X59 "pump dual" the correct part to pump out the drtain water?
Thanks much.
Paul
#2 Posted : Monday, July 14, 2008 12:36:26 PM(UTC)
Hi Paul,
This pump is a last thing I would think about in such situation.
The first thing I would check is the air gap on top of the sink (if there is one). Remove the top cover and the top piece and check the air gap for a clog.
Disconnect the drain hose from the air gap, or from the garbage disposer if there is no air gap, put the end of the drain hose in a bucket and run the drain cycle to see if there are any foreign objects inside the hose.
Post your findings.
Paul Radovsky
#3 Posted : Monday, July 14, 2008 12:44:01 PM(UTC)
Paul Radovsky
Gene,
I have a flexible hose that goes 32" + above the floor and it is all clear. All the other hoses are clear and the connection to the sink's drain pipe is clear. I also checked all the traps on the bottom inside and they have no garbage in them.
Any other thoughts?
Thank you very much.
Paul
#4 Posted : Monday, July 14, 2008 1:00:28 PM(UTC)
Paul,
Remove the filter frame (#543 on the break down diagram), unscrew and check the piston & nut assembly (#564 on the break down diagram). The rubber cone should close the center hole when it's in upper position and it should move freely up & down.
- The part number for the piston & nut assembly is AP2617344
Paul Radovsky
#5 Posted : Sunday, July 20, 2008 9:38:46 AM(UTC)
Paul Radovsky
Gene,
The cone is mostly eroded. I will replace that part as you recommended.
Thanks very much.
Paul
#6 Posted : Sunday, July 20, 2008 12:41:03 PM(UTC)
Hi Paul,
Keep us posted.
Guest (4)
