11 Pages«<45678>»
#51 Posted : Tuesday, September 7, 2010 3:36:35 PM(UTC)
Originally Posted by: APPNewbie Go to Quoted Post
Disassembly is work but not crazy. I would like to know if anybody has had the problem that I mentioned earlier where I do not get heat or blower. Any help would be appreciated. :)
What is the complete model number of the dryer?
APPNewbie
#52 Posted : Tuesday, September 7, 2010 3:45:38 PM(UTC)
APPNewbie
DPGT750EC2PL
#53 Posted : Wednesday, September 8, 2010 12:59:21 PM(UTC)
DPGT750EC2PL
Check the inverter as described in the attached instruction on the first page of this thread.
Here are the breakdown diagrams and Replacement parts for General Electric DPGT750EC2PL Electric dryer | AppliancePartsPros.com
APPNewbie
#54 Posted : Wednesday, September 8, 2010 4:30:06 PM(UTC)
APPNewbie
I will do this tomorrow and post results or a question if I run into a problem. Thank you very much for response. :D
jniggli
#55 Posted : Thursday, September 9, 2010 2:02:46 PM(UTC)
jniggli
If the blower motor stops... the heat will stop shortly after. If the blower motor doesn't run at all you will most likely feel no heat at all. Sounds to me like your problem is the same as everyone elses....bad blower motor caused by a bad transistor.
APPNewbie
#56 Posted : Friday, September 10, 2010 5:37:18 AM(UTC)
APPNewbie
You are most likely right. Today I am going to do the diagnostics that Gene recommended. It does make sense that the heat would stop after the blower motor stopped otherwise there may be a chance of a fire if the heater just kept on. Thank you for your very much for your input.
APPNewbie
#57 Posted : Friday, September 10, 2010 11:29:37 AM(UTC)
APPNewbie
Ok, all the voltages test correctly according to the voltages on the "Testing the Iverter" page except for the line voltage which read 125VAC. Is that too much for the unit? Do I have a problem with the RF Choke?:confused:
#58 Posted : Friday, September 10, 2010 4:25:55 PM(UTC)
I do not think so because it should work within 10% range. Sounds like the blower motor is the culprit.
- The blower motor Part number: AP3791484
APPNewbie
#59 Posted : Saturday, September 11, 2010 12:02:48 PM(UTC)
APPNewbie
Ok, I ordered the part and will post back when I install it next week. Thank you for your help. ;)
APPNewbie
#60 Posted : Saturday, September 18, 2010 2:23:38 PM(UTC)
APPNewbie
I installed the new motor on Thursday and the dryer has been working fine ever since.(We had a build up of laundry and we put the dryer through it's paces catching up.) Thanks everyone for responding even if you did not respond to my direct question. All of the input on this forum made a difference for me. :D
BTW, I think I read a thread on here that indicates that the motor can be rebuilt. Should I save the motor and rebuild it for the next time it goes out?:confused:
11 Pages«<45678>»
