3 Pages123>
fredp0275
#1 Posted : Tuesday, July 8, 2008 5:50:09 PM(UTC)
fredp0275
IT IS WORKING FOR ABOUT 2 YEARS AND THEN PLACE IN THE GARAGE FOR STORAGE FOR ABOUT 4 MONTHS. NOW I NEED IT, IT DOES NOT WORK. THE REFRIGERATOR AND FREEZER IS NOT COOLING, THE COMPRESSOR WILL NOT TURN ON BUT THE FAN IS WORKING, THE WATER IS AVAILABLE FROM THE DISPENSER. WHAT COULD BE WRONG? HELP, WHATEVER IDEAS OR SOLUTIONS YOU MIGHT HAVE GIVE IT TO ME.
THANKS,
FRED :confused:
#2 Posted : Wednesday, July 9, 2008 3:43:46 PM(UTC)
Hi Fred,
In what position the fridge was while it was in the storage? Did you transport it and if you did, in what position it was?
fredp0275
#3 Posted : Thursday, July 10, 2008 10:29:32 PM(UTC)
fredp0275
Hi Gene,
It was at a Normal Standing Up position. During the transport it is on it side for about 15 min, less than 1/2 a mile. Then I have it In a Normal Standing Up position about 2 Days before I plug it in. The fan is running but the compressor is not.
Fred
#4 Posted : Friday, July 11, 2008 11:06:41 AM(UTC)
Hi Fred,
Does the compressor make a clicking noise once in a few minutes or it's absolutely silent?
fredp0275
#5 Posted : Sunday, July 13, 2008 12:51:40 PM(UTC)
fredp0275
Hi Gene,
When I was observing it, It is absolutely silent.
Fred
D_A_4
#6 Posted : Sunday, July 13, 2008 1:53:40 PM(UTC)
D_A_4
Better check the compressor relay. One quick sign is if it sounds like a marraca when you shake it. Check the overload as well but its probably fine.
fredp0275
#7 Posted : Monday, July 14, 2008 8:49:39 AM(UTC)
fredp0275
Hi Gene,
Where is the location of start relay and the overload? I'm really exited, I can't wait to get home to check the relay and reset the overload.
Fred
D_A_4
#8 Posted : Monday, July 14, 2008 9:13:17 AM(UTC)
D_A_4
Originally Posted by: fredp0275 Go to Quoted Post
Hi Gene,
Fred
pull off the back panel and on the left side of the compressor you might have to pull off a cover or a small metal clip. unplug refrigerator and pry off the relay. ohm out the relay and overload. if bad replace, overload is usually fine.
-Drew
#9 Posted : Monday, July 14, 2008 8:03:46 PM(UTC)
Hi Fred,
Unplug the temperature control harness. Does the refrigerator start once the harness is unplugged?
If it did then replace the temperature control board.
If it did not then replace the main control board (on the back of the fridge). I would recommend to replace both refrigerator and freezer temperature sensors together with the main control board.
- The part number for the temperature control board is AP3183989
- The part number for the main control board is AP3950129
- The part number for the temperature sensor (they are identical) is AP3185407
fredp0275
#10 Posted : Monday, July 14, 2008 10:35:18 PM(UTC)
fredp0275
Hi Gene,
Where is the location of the temperature control harness / temperature control board? and the temperature sensors? I know where is the main control board (on the back of the fridge).
Fred
Guest (4)
3 Pages123>
