dkfreeman
#1 Posted : Thursday, September 2, 2010 4:11:02 PM(UTC)
dkfreeman
Water drips from the back center in the cool box directly under the freezer box. I suspect that the defroster unit is not evaporating the resulting water??? How can I further troubleshoot to determine the cause exactly? I have studied the parts exploded diagram and went to the refrigerator but I cannot determine exactly where the evaporator system is located and thus how to get to it? - to see it - to test it - and if I could, what tests should I perform?
Thanks for some clues - I am generally very handy but this one has me stumped.
#2 Posted : Friday, September 3, 2010 3:04:22 AM(UTC)
Remove the back freezer panel and check the drain, probably frozen. I use a turkey baster and hot water to flush it out.
dkfreeman
#3 Posted : Friday, September 3, 2010 6:09:08 AM(UTC)
dkfreeman
Thanks - Is that how I access the parts of the defroster? ... from the back? What can be done to help prevent it from freezing over and plugging again?
#4 Posted : Friday, September 3, 2010 12:21:17 PM(UTC)
Usually dirt gets in the drain and causes the clog. Use a turkey baster to force the clog out. You can try a 12 gauge copper wire wrapped around the heater and down the drain to thaw it during defrost period, not always possible though.
