The Support Arm broke on my old Maytag. I received the part without any instructions. It looks simple enough, but I'm not sure what to do with the rubber seal that shipped with it. It might be obvious when I take it apart, but I thought maybe someone has dealt with it before. Thanks for any help!
Originally Posted by: cc16  The Support Arm broke on my old Maytag. I received the part without any instructions. It looks simple enough, but I'm not sure what to do with the rubber seal that shipped with it. It might be obvious when I take it apart, but I thought maybe someone has dealt with it before. Thanks for any help! CC16, How's about a part number for the part, So we can give you a better idea of what to expect. Thanks, :) :) :)
Yes the part number is WPL 12001229
Originally Posted by: cc16  The Support Arm broke on my old Maytag. I received the part without any instructions. It looks simple enough, but I'm not sure what to do with the rubber seal that shipped with it. It might be obvious when I take it apart, but I thought maybe someone has dealt with it before. Thanks for any help! CC16, In your case you wont need the gasket/seal, just the support arm. The gasket was included in the kit for older units, it was not needed on your unit, because there was a re design of the pump assembly and cover. :) :) :)
Originally Posted by: cc16  Thanks for your help! You're welcome, If you need anything. Drop us a line We're here to help. :) :) :)
