olney5
#1 Posted : Tuesday, July 8, 2008 5:50:04 PM(UTC)
olney5
The drains are clear. It acts like it is not pumping so I suspected a bad drain pump.
Further checking verifies that the impeller turns and ALL of the drains are clear. Unfortunately, I removed the dishwasher from under the counter without running the diagnostics. Is this likely a controller problem since it gets information from the float and water level switches?
Thanks for your help.
Guy
#2 Posted : Wednesday, July 9, 2008 3:40:05 PM(UTC)
Hi Guy,
Did you check the drain pump motor for continuity?
olney5
#3 Posted : Wednesday, July 9, 2008 6:16:41 PM(UTC)
olney5
There is continuity across the drain motor. There is also continuity across the Normally Open side of the water level switch. Can a stuck water level switch cause the drain problem? If so, how do I get to it?
Thanks again,
Guy
abadfish66
#4 Posted : Wednesday, July 9, 2008 6:34:08 PM(UTC)
abadfish66
a stuck water level switch will cause a no fill situation, not a no drain.
#5 Posted : Wednesday, July 9, 2008 9:32:10 PM(UTC)
Guy,
I would recommend to put it back together and start it over.
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
Belarus Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
by av0612 8/6/2014 4:42:36 PM(UTC)
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 7/17/2014 7:31:44 PM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 6/10/2014 6:30:07 PM(UTC)
