my washer will not agitate or spin. it makes a very loud noise.
Most likely the problem is a bad motor coupling (#13 on the break down diagram). You can find the complete instructions in the Manual. - The part number for the motor coupling is AP3963893 Here are the break down diagrams for the Roper washer Model RAX7245KQ0Gene.
Thanks Gene, :) Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Most likely the problem is a bad motor coupling (#13 on the break down diagram). You can find the complete instructions in the Manual. - The part number for the motor coupling is AP3963893 Here are the break down diagrams for the Roper washer Model RAX7245KQ0Gene.
