I just replaced my Bosh listed control panel. It works great but when it get down to 1 minute the drain dose not work and it will not cut off. It is almost like it is not getting the message to drain and cut off to the cut off switch. I thought that maybe it might need cleaning, but don't know for sure. I replaced the complete control module because most of the pins were broken (made of plastic). I know that is good and it worked for the first round of use but now it gone back to not cutting off and not draining the dish washer.
Hi John,
Did you see a jumper plug on the right side of the old control module? If there was one it must be transfered to the new control module.
Gene. I did put the jumpers on and checked using the Bosh test program to troubleshoot the dishwasher. Everything worked very well but for some reason when it gets back to the 1 minute, it just keeps going and going. You can do a manual stop and that works but not sure what to do.
