I need a electrical wireing schematic for this unit. I would like to check out all the button thermostats and timers. There is no digram on back of box. If I can get a sequence of events I should be able to repair this unit. Thanks
Originally Posted by: retired72  I need a electrical wireing schematic for this unit. I would like to check out all the button thermostats and timers. There is no digram on back of box. If I can get a sequence of events I should be able to repair this unit. Thanks Retired 72, Is there other problems with your refrigerator ? At present I do not have access to G E wiring diagrams, that I can supply to you. But, a frozen fill tube to the ice maker is seldom due to an electrical problem. Most often, (98%of the time) a frozen fill tube is due to a seeping water inlet valve Part number: AP3672839
Occasionally, a freezer temperature thats is too low(reccomended freezer temp is 3 to5 degrees, and never below 0 degrees). I'm positive you will find your frozen fill tube is due to one of these areas. Check your freezer temperature and adjust as necessary, and order/replace the fill tube and de ice the fill tube with a hair dryer, and you'll be good as new. Good Luck, :) :) :)
