retired72
#1 Posted : Monday, August 16, 2010 10:38:07 AM(UTC)
retired72
I need a electrical wireing schematic for this unit. I would like to check out all the button thermostats and timers. There is no digram on back of box. If I can get a sequence of events I should be able to repair this unit. Thanks
Joe / APP Team
#2 Posted : Friday, August 27, 2010 1:43:04 PM(UTC)
Joe / APP Team
Retired 72,
Is there other problems with your refrigerator ?
At present I do not have access to G E wiring diagrams, that I can supply to you.
But, a frozen fill tube to the ice maker is seldom due to an electrical problem.
Most often, (98%of the time) a frozen fill tube is due to a seeping water inlet valve
Part number: AP3672839
Occasionally, a freezer temperature thats is too low(reccomended freezer temp is 3 to5 degrees, and never below 0 degrees).
I'm positive you will find your frozen fill tube is due to one of these areas.
Check your freezer temperature and adjust as necessary, and order/replace the fill tube and de ice the fill tube with a hair dryer, and you'll be good as new.
Good Luck,
