photo2u
#1 Posted : Friday, August 27, 2010 1:25:50 PM(UTC)
photo2u
[FONT='Times New Roman','serif']Hello dear friends in forum,[/FONT]
[FONT='Times New Roman','serif'] [/FONT]
[FONT='Times New Roman','serif']I am having trouble with a Viking vgr48-6(very old model with griddle, 6 burners, broiler and two burners) I believe it was made by us range. Anyways, I am helping a friend who asks me to do a complete overhaul in the stove. I am having trouble getting any sparks sounds or anything from the range. I cleaned the 3 spark igniters and they are very clean. I replaced the spark module Harper-Wyman, Kool Lite model 6521, 120V, 4ma. With a Maytag ignition module, part number AP204776 from your website. I have read in previous post that the spark module would work well as a replacement for the kool lite 6521.[/FONT]
[FONT='Times New Roman','serif']The problem is this: I do not get any sounds or sparks after properly installing the new module. [/FONT]
[FONT='Times New Roman','serif']This is what I have done in order to solve the problem:[/FONT]
[FONT='Times New Roman','serif'] [/FONT][FONT='Times New Roman','serif']1. [/FONT][FONT='Times New Roman','serif']I check The gap between the igniter and the burner and it look ok less than two dimes thickness.[/FONT]
[FONT='Times New Roman','serif'][/FONT][FONT='Times New Roman','serif']2. [/FONT][FONT='Times New Roman','serif']I also made contain that the spark igniter’s lines were properly connected. [/FONT]
[FONT='Times New Roman','serif']Am I missing something? [/FONT]
[FONT='Times New Roman','serif']Please advice,[/FONT]
[FONT='Times New Roman','serif']George[/FONT]
[FONT='Arial','sans-serif'] [/FONT]
#2 Posted : Friday, August 27, 2010 3:23:49 PM(UTC)
Make sure there is proper voltage coming to the range. Try to bypass any of the ignition switches.
photo2u
#3 Posted : Friday, August 27, 2010 5:42:25 PM(UTC)
photo2u
yes!
Thanks your your info.
I also check to voltage with the new module. It was 17 volts in two and 13 on the other two. This particular module has four.
Maybe, I did not check the voltage correctly, It was a little odd to get to different voltage reading from my module. However I did remember checking the voltage readings 3 times.
George
Guest (4)
no spark with range viking old model (Oven Repair (including Ranges and Cooktops))
by photo2u 8/27/2010 1:27:56 PM(UTC)
