SINDONE
#1 Posted : Sunday, July 6, 2008 11:23:06 AM(UTC)
SINDONE
I need an answer. My dryer won't start but the timer runs. I think it may be thermal fuse. If it is do I have to replace the thermostat too. I also need a diagram for this model. Also see previous message.
MJM
#2 Posted : Monday, July 7, 2008 8:56:16 PM(UTC)
MJM
The Virtual Repairman's Appliance Help :: Index are much more quicker with a correct answer for you I hope this helps you...I waited as I guess lots on here do for some help..good luck..MJ
#3 Posted : Tuesday, July 8, 2008 2:01:50 AM(UTC)
Short the wires going to the narrow, white thermal fuse on the blower housing, then verify the dryer is working, then order a new one.
Guest (4)
