Rickfromchurch
#1 Posted : Tuesday, August 24, 2010 5:00:41 PM(UTC)
Rickfromchurch
Fan cycles on and off. Sounds like it is coming from behind the ice maker. Up high in the unit. This began afer a 5 hour power outage. Freezer is working but some food in freezing in the refer side.
Help?
#2 Posted : Wednesday, August 25, 2010 2:25:13 AM(UTC)
Replacement parts for FRIGIDAIRE FRS26RLECS0 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389615.pdf
And a manual which may help though it does not specifically list your unit.
http://frigidaireservicetips.com/pdfs/495_2.pdf
Since the problem started after a power outage my guess would be that the adaptive defrost board is shot.
Another possibility is that the damper control switches are not operating correctly.
Kenmore evaporator fan cycles on and off (Refrigerator & Freezer Repair)
by kelly.kendrick@me.com 1/16/2022 1:43:06 PM(UTC)
Evaporator Fan cycles on and off. Amana BRF20VSE. (Refrigerator & Freezer Repair)
by mattgitlin 11/6/2014 8:36:13 AM(UTC)
