2 Pages12>
Bigfoot100
#1 Posted : 15 years ago
Bigfoot100
We have an old RCA fridge that has worked fine for years. Recently the fridge door was left open all night due to a storage container sticking out too far. Ever since then, it runs continously. The temperature of things in the fridge is fine, and the freezer contents and ice are fine too. I can turn the "Fresh Food" control dial down to OFF, and it will go off. But once I turn it up again, it comes on and stays on.
I checked the door gasket (and cleaned it), and while it does have a couple of cracks it seems to seal just fine.
Also, I cleaned all the coils underneath the fridge, but nothing changed.
Any tips would be greatly appreciated.
#2 Posted : 15 years ago
Replacement parts for General Electric MSX27XLB Refrigerator | AppliancePartsPros.com
I would remove the evaporator coil cover in the freezer and check the coils.
If they have ice on them you may want to manually defrost the unit.
Could be that with the door left open the coils iced up so much that it will take several defrost cycles to clear everything.
While you have the cover off you may as well also check the defrost components.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 257 in Section 4) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the heater and defrost thermostat are OK
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Bigfoot100
#3 Posted : 15 years ago
Bigfoot100
WOW! Thanks for the great tips. I do have a meter, and will go thru your suggestions this weekend. Really appreciate the great advice!!!
Also, I didn't realize that this is effectively a GE appliance...
Bigfoot100
#4 Posted : 15 years ago
Bigfoot100
Ok, I removed all of the contents of the freezer, including the shelves, and removed the plastic cover from the back wall, which revealed a bunch of coils. They have a thin layer of frost on them, but nothing excessive. I could easily scrape it off with my fingernail. And I can see the silver color of the metal coils, so it's not like their covered in frosty white ice.
So, should I still check the defrost components?
Bigfoot100
#5 Posted : 15 years ago
Bigfoot100
I just turned the defrost timer until everything went OFF, and then found heating elements in the freezer near the evaporator coils were heating right up. So I guess this means the defrost components are working too.
Help?
#6 Posted : 15 years ago
[COLOR="Blue"]So I guess this means the defrost components are working too.[/COLOR]
Yes it sounds like the defrost is OK.
Especially since the coils only had a light coating of frost. For defrost to cause a problem the coils must be frosted/iced over to the point where the evaporator fan cannot pull air through them.
Does the evaporator fan in the freezer run?
It is required for the unit to cool efficiently.
Was the frost coating on the coils fairly even?
If there was only frost in one area usually where the freon enters the coils or if it was very blotchy, it is an indication of low freon or a sealed system problem.
Is the condenser/compressor fan running?
This also can produce poor cooling.
Also are the condenser coils clean?
Bigfoot100
#7 Posted : 15 years ago
Bigfoot100
Back again, sorry, had to tend to other things for a while.
YES, the fan behind the icemaker in the freezer seems to run fine, and YES, the frost coating on the coils was even throughout.
I assume the condenser coils are the coils underneath the unit, that you clean by removing the grill? Yes, they are clean. How do I find/check the condenser fan? Is it accessible from underneath...?
Thanks.
#8 Posted : 15 years ago
[COLOR="Blue"]How do I find/check the condenser fan?[/COLOR]
Item 650 in Section 5 of the parts.
[COLOR="Blue"] Is it accessible from underneath...[/COLOR]
You can get to it by removing the rear cover (Item 616 in Section 5)
Bigfoot100
#9 Posted : 15 years ago
Bigfoot100
So, is that cover on the backside? That is, I need to pull the fridge away from the wall to remove it and get access to the condenser fan?
#10 Posted : 15 years ago
Yes, you have to pull the fridge away from the wall.
2 Pages12>
