praxia
#1 Posted : Saturday, August 14, 2010 12:53:12 PM(UTC)
praxia
Lower element broke (in 2 pieces). All other items on the range worked (stove top, broil and time display). I replaced the element through an authorized Maytag parts store.
Upon replacing the element, only the time display works. The stove top, broil and lower element do not come on. The stove top lights to indicate they have been turned on do not work. I can still specify a temperature for the oven, but it never heats up. Set the auto-clean to three hours and cancelled after 15 minutes. The oven "never" warmed up.
There are no "F" errors on the display.
Does anyone have any ideas on what could be wrong? Please assist. Thank you.
#2 Posted : Saturday, August 14, 2010 2:32:26 PM(UTC)
Replacement parts for MAYTAG CRE9600BCE Range - S/c F/s Ele | AppliancePartsPros.com
It sounds like a power problem.
The elements all require the full 240 volts while the controller and klights only require 120 so it sounds like you have lost half the line.
Try turning the breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
kayakcrzy
#3 Posted : Sunday, August 15, 2010 5:51:21 AM(UTC)
kayakcrzy
I would pull the oven out, and look and see where the cord goes into the oven, that there is not a burn't wire back there. If not, the clock control will be your problem. Tom ApplianceEducator.com - Parts
praxia
#4 Posted : Sunday, August 15, 2010 11:40:54 AM(UTC)
praxia
Thank you both for the suggestions. I have talked to my neighbor who is an electrician and he is going to come over and take a look. Will post how it turns out.
kayakcrzy
#5 Posted: : Sunday, August 15, 2010 4:22:40 PM(UTC)
kayakcrzy
Let me know what you find. Tom
praxia
#6 Posted : Wednesday, August 18, 2010 3:18:35 PM(UTC)
praxia
Well, my neighbor forgot about coming over so we ended up contacting another company to provide an estimate. When the technician arrived, he turned the circuit breaker to off, waited about 5 minutes and then turned it back on and everything worked fine until the oven was turned on. He checked the voltage on the outlet and found that it would only read 120v. Again, the circuit breaker was turned off and this time we waited 10 minutes. At which time, everything powered up fine with no problems and it is still working at this time. So it appears that the circuit breaker may be faulty. I will replace it this weekend and hopefully all will be well again.
kayakcrzy
#7 Posted : Thursday, August 19, 2010 4:08:27 AM(UTC)
kayakcrzy
I really had a feeling there was a power issue!! Good Luck!!!
#8 Posted : Tuesday, August 24, 2010 3:33:01 AM(UTC)
Thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
