I am unsure of what color wire go to what terminal. NEG GRD and E1 E2 not sure can someone tell me what color go where. I have red black green yellow
Do you have a model# of the range? What are you replacing?
I am installing a new ERC board and a new touch pad. the person who took the ERC out is not around and I can install it and did but unsure of where all the wires go to. I can use guess from the length and install but dont want to kill a $350.00 part I just install. NEG GRD E1 E2 and I think one more.. I thik the colors are greed black red (split to 2 wires) yellow and blue..
Ge profile stove jgbp79wew1ww The stove was beeping and beeping so I disconnect the pad tuen on power and beeping stop when the ERC was connected. When I reinstall the ribbon cable for the pad beeping and f1 code came back ..I was told the Pad is bad and needed replacement...
Yellow is bake Blue is broil white is nuetral green is ground red/black is line
Thanks but can you tell me the pin number I think I see GND E1 E2 what color go to E1 E2. BA I guess is BAKE BR Boril ..thnks.. I am going to do this power test one more time to make sute my touch pad is bad before spending 350 on a new pad.
I was told to disconnect the pad power up for an 1 hr is no beeping or F1 the pad is pad. If beeping and F1 than it is the ERC. Do you know if this is correct.I apply power for about 45 mins no beep I power done install touch pad beep started with in 3minutes with F1 so i am thinking it is the pad...
Yes, the touch pad is bad....where do you see E-1 E-2, I'm looking at the wiring schematic, but don't see those markings?
Are you sure it's not L1 and L2, these are your red and black hookups
I think it might be L1 and L2 I am at work trying to off the old brain here. I do remember like a BA pin and a BR I think if you can tell me color to those BA=Bake Yellow BR=BROIL BLUE
BA=bake=yellow BR=broil=blue GND=ground=green NEU=neutral=white L1=line1=black L2=line2=red
Hope that helps
I am going to test one more time before ordering the touch pad So far your site is the best deal in town so I will order one on Monday morning.. ..thanks..sunil
