sunil517
#1 Posted : Thursday, July 3, 2008 8:37:48 AM(UTC)
sunil517
I am unsure of what color wire go to what terminal.
NEG GRD and E1 E2 not sure can someone tell me what color go where.
I have red black green yellow
abadfish66
#2 Posted : Thursday, July 3, 2008 8:47:31 AM(UTC)
abadfish66
Do you have a model# of the range? What are you replacing?
sunil517
#3 Posted : Thursday, July 3, 2008 9:32:21 AM(UTC)
sunil517
I am installing a new ERC board and a new touch pad.
the person who took the ERC out is not around and I can install it and did but unsure of where all the wires go to. I can use guess from the length and install but dont want to kill a $350.00 part I just install.
NEG GRD E1 E2 and I think one more..
I thik the colors are greed black red (split to 2 wires) yellow and blue..
Ge profile stove jgbp79wew1ww
The stove was beeping and beeping so I disconnect the pad tuen on power and beeping stop when the ERC was connected. When I reinstall the ribbon cable for the pad beeping and f1 code came back ..I was told the Pad is bad and needed replacement...
abadfish66
#4 Posted : Thursday, July 3, 2008 11:03:08 AM(UTC)
abadfish66
Yellow is bake
Blue is broil
white is nuetral
green is ground
red/black is line
sunil517
#5 Posted : Thursday, July 3, 2008 11:20:39 AM(UTC)
sunil517
Thanks but can you tell me the pin number
I think I see GND E1 E2 what color go to E1 E2.
BA I guess is BAKE BR Boril ..thnks.. I am going to do this power test one more time to make sute my touch pad is bad before spending 350 on a new pad.
I was told to disconnect the pad power up for an 1 hr is no beeping or F1 the pad is pad. If beeping and F1 than it is the ERC. Do you know if this is correct.I apply power for about 45 mins no beep I power done install touch pad beep started with in 3minutes with F1 so i am thinking it is the pad...
abadfish66
#6 Posted : Thursday, July 3, 2008 11:30:48 AM(UTC)
abadfish66
Yes, the touch pad is bad....where do you see E-1 E-2, I'm looking at the wiring schematic, but don't see those markings?
abadfish66
#7 Posted : Thursday, July 3, 2008 11:43:40 AM(UTC)
abadfish66
Are you sure it's not L1 and L2, these are your red and black hookups
sunil517
#8 Posted : Thursday, July 3, 2008 12:03:58 PM(UTC)
sunil517
I think it might be L1 and L2 I am at work trying to off the old brain here.
I do remember like a BA pin and a BR I think if you can tell me color to those BA=Bake Yellow
BR=BROIL BLUE
abadfish66
#9 Posted : Thursday, July 3, 2008 12:09:26 PM(UTC)
abadfish66
BA=bake=yellow
BR=broil=blue
GND=ground=green
NEU=neutral=white
L1=line1=black
L2=line2=red
Hope that helps
sunil517
#10 Posted : Thursday, July 3, 2008 12:16:19 PM(UTC)
sunil517
I am going to test one more time before ordering the touch pad
So far your site is the best deal in town so I will order one on Monday morning.. ..thanks..sunil
